Hi Folks,
Somemore things to clear! Slowly digging out from my "goldmine" hahaha
1) HK FLYCAT Kit - Brand New with 2 x NEW Hextronic Servos - Asking $30 only
Built this kit half way while waiting for my 60A ESC to come in my interest died down.
Things that i have already done -
a. Main fuselage epoxied together
b. HXT900 servos installed
c. Motor mount epoxied into place with a 10degree offset for thrust angle
d. Wing + Rear stabilizer nicely spray painted with bright orange for easy orientation
e. Canopy spray painted black for aesthetics
f. Small opening made at side of fuselage to run wires out for ESC to be mounted outside on main wing as reccommended on internet
Comes with original Box, Manual, Stickers.
You can use a rear pusher set up for this fella using a 2700kv motor running on 6x4 Prop on 3S batt or you can use the included EDF Fan for a EDF setup. Its cheap and whole lot of fun as long as you get the CG right!
2) BRAND NEW 450 Class ESKY CP V2 Main blades (White) 325mm - 2 Sets, take both for only $15
I bought these as spares, buy 2 together at same time kiasu! hahaha Its wooden, stiff and very lightweight. Cheap and good if you want to use this to practise first and in case crash, not so heartpain.
3) BRAND NEW 700 Class Landing Skid + Skid Pipes - Asking for only $15
Wanted to fit this onto a Quad but alas the dimension is not right. Sitting around collect dust.
Let me know if you are keen! As usual FCFS!
