ReadyToFly : SkySurfer Glider c/w Transmitter
    Postby Mikalim ยป Wed 01 Jan 2014 9:17 am
    Ready to Launch Plane Set
    1 . Sky Surfer Glider ----- 1 set ( New w/o packaging )
    - Wing Span : 1400mm
    - Length : 925mm
    - Flying Weight : 650g
    - Motor : Brushless Outrunner
    - ESC : Brushless 20A
    - Servo : 9g, 1.3-1.8kg/cm, 0.12s/60
    2 . 1800mAH Lithium Polymer Battery ----- 3 pcs ( Used )
    3 . Li-Po 3-Cell Battery Charger ----- 2 pcs ( New )
    4 . AC-12vDC adaptor ----- 1 pc ( New )
    5 . Tahmazo TL-4 Parallel Lithium charger ----- 1 set ( New w/o packaging )
    - Durable and light weight aluminum case
    - Charges the lithium polymer battery pack usings its Constant Current and Constant Voltage charging technique
    - Charges each cell of the battery pack indendently
    - Load polarity protection
    - Input polarity or reverse polarity protection
    - Built-in fan for maximum heat dissipation
    - Automatically cut-off when the input power supply falls below 8v
    - Weight : 310g
    - Dimension : 138 x 89 x 35mm
    - No. of Lithium Cells to charge : 1-4
    - Max. Charge Current : 2.0A
    - Input Voltage : 12-15v
    6 . FUTABA T6-XA Transmitter ( aka remote control ) ----- 1 set ( Used )
    7 . Receiver ( linked to transmitter ) ------ 1 pc ( New )
    8 . AC Adaptor to charge Transmitter T6-XA ----- 1 pc ( Used )
    9 . Sky Surfer Manual ----- 1 set ( New )
    10 . T6-XA Transmitter Manual ( photocopied ) ----- 1 set ( New )
    11 . Foam safe glue ( for repairs ; brand new in foil packaging ) ----- 1 bot ( Brand New in Packaging )
    The plane is fixed up and ready to launch.
    The transmitter and receiver are linked and all basic calibration is done. Minor calibration may be required.
    Most items are used as I am giving up this hobby.
    Selling @ S$ 250.00 nego.
    Text me @ 9360 1244.
    Self collect @ Jurong East.
    Testing upon payment is welcome.
