E-Station BC6 Dual Power AC/DC Charger
    Item Description: Bantam E-Station BC6 Dual Power AC/DC Charger
    The BC-6 is AC and DC compatible right out of the box, no external power adapter needed. Charge up to 16 cells of NiCd/NiMH and 6S of Lithium batteries with a maximum charge rate of 5.0A. The BC-6 has an individual-cell-voltage balancer built in, so you won't need an external balancer when charging Lithium batteries (Li-Ion/LiPo/LiFe). High-quality aluminum case is durable and helps the charger cool efficiently.
    Specs
    Input Voltage 11-18V DC or 100-240V AC, 50/60Hz
    Circuit Power 50 watts max
    Number of LiPoly Cells 1-6 cells
    Number of NiMH/NiCad Cells 1-15 cells
    Pb Battery Voltage 2-20V
    Charge Rate 0.1A-5.0A
    Used or New : Used
    Condition & Age if Used : Used Good
    Price : $65
