WTS: Lots of stuff, for cheap.
    Hi guys, clearing out my stores yet again as I focus on the things in the hobby I like . I have way too much junk! Some stuff previously unsold going up, some new stuff going up.
    Please SMS me at nine, eight, 24, ninety, ten to deal. Please make sure to include item number so I know what you want. Please don't PM, I rarely check and it will throw the order off. Reservations are OK but don't reserve for too long. Self collect at my place in the east, or if not convenient we can see how to make things easier if you're serious to buy.
    ITEM 1: 1x Electrifly Gee Bee R1. Comes with manual and all the rigging which I never put on. Condition 6/10. There was a mishap on the maiden flight and the cowling came off, getting chewed up by the prop. Otherwise the rest is all OK. It's not a beginner plane, you need to be at speed to have any kind of control surface authority, but she looks pretty in the sky.
    You will need your own batteries (3S 2200mah) and rx to fly.
ID:	995119Click image for larger version
    Bought from NTC at over $220. Asking SGD$100, slightly nego.
    ITEM 2: 1x Durafly Auto-G, this is the v1 without the motor to spin up the rotor blades. Condition 9/10, flew her maybe 5-6 times. Very unique look in the sky, and needs lots of rudder work to fly. Plus, she prefers a slight breeze to get the blades spinning for takeoff.
    You will need your own batteries (3S 1300mah) and rx to fly.
    Bought from hobbyking for USD$74.99. Asking SGD$40. This one not nego, it is in fantastic condition!
    ITEM 3: 1x Stripped down RCExplorer tricopter frame. My first multi-rotor. Flies well but the slight flex in the booms makes putting a camera on it unfeasible. I learnt to do a basic tune and fly multirotors on this frame. Plenty of crashes but the beauty is that it is dirt cheap and easy to repair - remove boom, get new boom, cut and drill a hole if necessary, attach boom, ziptie, done!
    It consists of:
    • the black fibreglass top and bottom plates - bought from dadde himself, before he got internet famous on flite test!
    • 3x wooden booms already screwed in
    • anti-vibration battery tray
    • 3x 18A turnigy plush ESCs wired with xt60 connetor.
    • LEDs on the booms, so night fly if you want to! I don't know if I got the red/green order right, though.
    • Yaw mechanism plus servo. I'm quite proud of this yaw mechanism, it is super ghetto but has very little slop and is quite steady.
    You will have to supply:
    • multirotor control board (I used the kk2.0 on this guy)
    • 3x motors and props
    • battery
    • rx
    I will also throw in 3 or 4 DT750 motors and whatever 11" props I got for them. Please note, the motors are not "sold" but are a gift. This is because I suspect there is something wrong with one of them, probably a shot bearing due to one of my noob crashes. They will still fly the tricopter fine but I wouldn't use them for anything more than that. If you want to diagnose and then use the motors, cool! If not they're free, feel free to use in other projects. I know they're good for a 12x6 wood prop on 3S.
ID:	995122Click image for larger version
ID:	995123Click image for larger version
ID:	995124Click image for larger version
    Asking SGD$50, non-nego.
    ITEM 4: Bag'O'Servos! 26 servos in all, BNIB or used only once, mixture of digital/analogue and metal/plastic, mostly 9g size but some are slightly bigger and some are smaller. Use for your scratch-builds or keep as potential spares. Please see the picture for reference, there are a mixture of corona 939s, hxt500s, powerHD and random HK servos. Even got 1x multiplex polo digi 4 servo which probably costs more than what I'm going to sell the entire lot for (!).
Name:	IMG_1352 annotated.jpg
    Asking SGD$80 for the lot.
    ITEM 5: 3x Hitec HS 7245MH servos. Used only a handful of times, I think fewer than 5, max 10, they are condition 9.9/10.
    Each one SGD$40, take the lot for SGD$100. That's less than half off retail!
    ITEM 6: 1x wireless 9 in 1 sim adaptor. This one from HK: http://www.hobbyking.com/hobbyking/s...r_adapter.html
    Asking SGD$10.
    ITEM 7: 1x wired sim adaptor. This one from HK: http://www.hobbyking.com/hobbyking/s...ight_G4_5.html
    Asking SGD$5.
    ITEM 8: Motor mount, 94mm for EMP C6364 motors. Bought wrongly for $16, take it for FREE.
    ITEM 9: wiring combo! About a metre each of 8AWG, 10AWG and 12AWG wires, plus more 6mm, 5.5mm connectors you can shake your fist at. Use for your high amp applications. I don't even remember how much it all cost, take it all at SGD$5.
    ITEM 10: OrangeRX R410 spektrum compatible 4ch ultra micro rx. Forgot I had this. Take it for SGD$5.
    Update:
    Item 1: Gee Bee
    Item 2: Auto-G
    Item 3: Tricopter frame - RESERVED FOR VIEWING
    Item 4: Bag of servos
    Item 5: 7245s x3
    Item 6: Wireless 9 in 1 sim adaptor - RESERVED
    Item 7: Wired sim adaptor
    Item 8: Motor mount (free item)
    Item 9: Wires and plugs - RESERVED
    Item 10: Orange RX
      Update:
      Item 1: Gee Bee
      Item 2: Auto-G
      Item 4: Bag of servos - RESERVED
      Item 5: 7245s x3 - RESERVED
      Item 7: Wired sim adaptor - RESERVED
      Item 10: Orange RX
        Update:
        Item 1: Gee Bee - RESERVED
        Item 2: Auto-G
        Item 10: Orange RX
          Update:
          Item 2: Auto-G
          Item 10: Orange RX
            Update:
            Item 2: Auto-G - RESERVED
            Item 10: Orange RX
              Update:
              Item 1: Gee Bee - SOLD!
              Item 2: Auto-G - SOLD!
              Item 3: Tricopter frame - SOLD!
              Item 6: Wireless 9 in 1 sim adaptor - SOLD!
              Item 9: Wires and plugs - SOLD!
              Item 10: Orange RX - SOLD!
