I bought RTF Blade nanoQX mode 2.
But I used to fly my craft with mode 2 and with throttle stick reverse. (Throttle stick goes down for max power).
The RTF TX do not have the function to reverse the throttle stick...so I decide to modify it by changing the potential port connection. (See the pictures below)
After the modification, I finally manage to control my nanoQX without having to re-lean the control over again.
So, for those who are in the same situation with me, here is how:
All u need to do is to desolder the throttle's potential port out from the PCB.
Bend the 1 and 3 pins so that when solder back, only pin 2 (middle pin) is connected back.
Soldered 3 wires for pin 1 and 3.
Reverse the pin 3 and 1 and solder it back to the PCB.
Reconnect and re-soldered everything back.
That is all.
That is all.
