A very powerful AV wireless transmitter and receiver for FPV.
Description:
1. Very light and ultra mini size
2. The mini but powerful 5.8GHz 2000mw transmitter would allow transmission 7-9 km away with only the stock antenna
3. Advanced build-in regulator offers this transmitter very wide power input range.
4. 5.8GHz NEW 2000mw transmitter is light, compact and powerful, a very good choice for 5.8G long range FPV.
5. This transmitter is compatible with all 5.8G VRX like RC305, RC805, AIO goggles and 5.8G DVR DV01.
Specificaiton:
Transmitter frequency: 5645-5945MHz; 8CH
Transmitting Power: 2000mW/26dBm
Transmitting distance: >7000m(open area) - Longest range of transmitter so far
Frequency control: With channel button to change channels easily, display channel number, channel memory function for power-off
AV input: Analog AV signal input
ANT connector: RPSMA(hole inside)
Power supply: 9-16 volts
Current supply: 300mA
Receiving frequency: 5665-5945MHz;8CH
Receiving sensitivity: -90dBm
Frequency control: Built-in frequency and phase lock loop
AV output: Analog AV signal output
Antenna connector: RPSMA(hole inside)
Power supply voltage: 4.6-16V
Supply current: 60mA
Dimension: 55*40*14mm(aluminium shell)
The old version receiver RC305 and RC805 in the current market is 150mAh, This new model receiver is only 60mAh. Thus, the battery life can be at least 2.5 times longer than the RC305 and RC805 model. It is also smaller in size.
This is a brand new set with all all cables provided. Selling for $250 (fixed). Interested please contact Rog at 9023 3811.
