WTS: Mastor-G brushless gimbals for gopro
    Based on STM32 32-bits high-speed MCU(tens of times faster than other open-source solutions)
    Support Gopro Hero1/2/3 HD camera and some small DC under 200g
    Super easy to configure based on intelligent PID adaptive algorithm, nearly plug and play, what you need is just to adjust the COG of different cameras, and adjust the power output parameter according to the weight of the camera, no need PID adjustment.
    Suitable for multi-rotor bigger than 450mm wheelbase, 700 class or bigger helicopter and airplanes with wingspan over 1.8m
    Weight: 232g without camera
    Roll angle limit: > 360 degrees
    Pitch angle limit: >180 degrees, can be controlled by any proportional channel(stick or knob, recommend), 3-positional switch channel
    Stabilizing speed: roll: 178 degrees/s; pitch: 182 degrees/s
    Control accuracy: roll: 0.07 degrees; pitch: 0.05 degrees
    12-hours angle drift: 0.12-1.5 degrees
    Suitable payload: 120g-400g
    Recommend camera: gopro hero1,hero2, hero3, or similar cameras
    Suitable flying wind Speed: < 38km/h
    Power: 2-4 cell lipo, 3-cell recommend, can be powered as high as 6-cell(the high voltage input need to be reduce the power output parameters in the configuration tool.)
    Current:160mA ~ 400mA
    Support AV out
    COG adjustment range: X: 28mm Y:12mm Z:36mm
    one month old
    selling coz upgrading to Zenmuse H3-2D Gimbal
    Selling at : $430
    condition: 10/10
    with orginal box
    PM at 86816708
