Batteries, Elecs, Mini Protos Parts
    Clearing out some bits and pieces I no longer require.
    1. DSMX Satellite (SPM9645) - $25
    2. 5 X Revo 4S 60C 2200MAH batteries - $100 for all of them, they have had about 30 cycles and are still showing low IR, have plenty of punch and have always been kept at storage charge
    3. 1 X Revo 6S 60C 4400MAH battery - $110 - it has had 10 cycles and is as good as new
    4. Blue Mini Vbar 5.3 with Pro Upgrade - $250
    5. 3 X MKS DS95 and 1 X MKS DS95i servo (with numerous spare servo arms) - $240 - these are the best 450 size servo's, two of the DS95's have had some of the protective coating on one of the wires fray due to rubbing
    on the CF frames, I have flowed some solder into the wire and covered it with heat shrink, they have been working flawlessly for 75+ flights like this, I have priced them cheap to reflect this
    6. A pile of Mini Protos parts from my spare Mini P - $125 (parts worth at least double this) here is a breakdown of whats included.
    * Complete Low FBL Hub with Spindle and Grips
    * Complete Tail with shaft, grips and tail blades
    * 2 X Strech Tail Booms and 1 X Stock Tail Boom
    * 350mm SAB FBL Blades
    * Spare Yellow Tail Blades
    * Lynx Carbon Fibre Tail Fin & Lynx Aluminium Tail Servo Mounts (Red)
    * Main Gear
    * Swash Plate
    * Landing Skids
    * Brand new in packet Feathering Shaft & Tail Shaft
    * Standard Tail belt
    * Complete Tail Case
    * Various other little bits and pieces (refer to pic)
    PM or SMS/Whatsapp me @ 98261886
Name:	2013-05-27 22.15.35.jpg
ID:	991096Click image for larger version
Name:	2013-05-27 22.20.05.jpg
ID:	991097Click image for larger version
Name:	2013-05-27 22.33.15.jpg
    Mini Vbar and DSMX Satellite both sold.
      Everything except for the Mini Protos parts has now sold.
        All Sold guys! Thanks
