SERVO
Hitec HS82-MG (New in Box) (selling 4 for $70)(2 sets)
Hitec HS325-HB (New in Box) (Selling 4 for $50)
MOTOR + ESC SET
Himax Motor + Multiplex ESC Set (New in Box) (Selling 1 set for $150)
Comes with:
1 x Himax C3528-1000 brushless motor
Power: 450W(3S)
KV: 1000
ESC Rating: 60A
Weight: 197g
Diameter: 35.2mm
Length: 54.2mm
Shaft Diameter: 5mm
Prop Size: 12x6 - 14x8.5
1 x MULTIcont BL-54 speed controller
Z Cell count, NiXX / LiPo, with BEC: 5 - 9/2 - 3S
Cell count, NiXX / LiPo, excl. BEC: 5 - 12/2 - 3S
Permissible continuous current: max. 54 A
BEC voltage: 5,0 V
BEC current: max. 3,0 A / max. 3,0 W
Pulse frequency: 13 kHz
Dimensions (L x W x H) approx.: approx. 51 x 28 x 9 mm
Weight (incl. cables): ca. 37 g
Himax Motor + Multiplex ESC Set (Used) (Selling 1 set for $150)
1 x Himax C4220-0510 Brushless Motor
Power: 5-6S
KV: 510
ESC Rating: 40A
Weight: 205g
Shaft Diameter: 5mm
1 x MULTIcont BL-55 SBEC Speed Controller
Cell count NiXX / LiPo with BEC 6 – 25 / 2 - 6S
Permissible continuous current max. 55 A
BEC voltage 5.0 V
BEC current max. 2.5 A
Pulse frequency 8 kHz or 16 kHz (variable)
Dimensions (L x W x H) approx. 76 x 28 x 11 mm
Weight incl. leads, plugs and sockets approx. 49 g
HK Heli 500 Motor + ESC (New in Box) (Selling 1 set at $40)
Comes with:
1 x Turnigy 500 H3126 Brushless outrunner 1600KV
Model: 3126
Turns: 4
Cells: 2~6S
Kv: 1600rpm/V
No load Current: 4.1A/10V
Max power: 1500W
Weight: 186g
Shaft diameter: 5mm
Dimensions: 37.2 x 42mm
Recomended ESC: 2~6S/70A
1 x Hobbyking SS Heli Series 70-80A ESC w/UBEC
Weight: 80g
Cells: 6-20Ni MH ~ 2-7S Li Po
Max Current: 70A
Burst: 80A
UBEC: 5A
Timing: 1/7/15/30 programmable
PWM: 8/16K
MOTOR + ESC SET
Comes with:
Power: 450W(3S)
KV: 1000
ESC Rating: 60A
Weight: 197g
Diameter: 35.2mm
Length: 54.2mm
Shaft Diameter: 5mm
BEC voltage: 5,0 V
Power: 5-6S
KV: 510
ESC Rating: 40A
Weight: 205g
Shaft Diameter: 5mm
BEC voltage 5.0 V
Comes with:
Model: 3126
Turns: 4
Cells: 2~6S
Kv: 1600rpm/V
Max power: 1500W
Weight: 186g
Shaft diameter: 5mm
Weight: 80g
Max Current: 70A
Burst: 80A
UBEC: 5A
PWM: 8/16K
