The Skywalker Falcon is a 1340mm span flying wing constructed from super durable EPO. This model is supplied in kit form allowing you to fit the airframe out however you wish.
Ideally designed and suited to a brushless outrunner pusher power system for flat field flying. There's plenty of space beneath the canopy making mini FPV a definite possibility. The Falcon also doubles an extremely durable slope soaring model - with plenty strength thanks to three carbon spars through the wing and slope friendly EPO.
The Falcon ticks a lot of boxes! Featuring electric friendly design considerations; such as an external ESC mount to expose your ESC to cooling airflow and moulded in cable runs. The top mounted servos keep the control linkages off the ground and prevent servo stripping on rough landing areas.
Building and fit-out are extremely quick and straightforward. Requiring just a few medium CA joints on the fins and wings. Then just add your radio and power system and you are done! Even the decals are pre-applied for you!
Spec:
Wing Span: 1340mm
Overall Length: 620 mm
motor: 2208 to 2215 size, 1800 to 2200kv
Battery: 3S 1500 - 3s 2200mAh Lipo
Propeller: 5x5-6x4
Weight: 510g
Condition is 7/10:
$35 comes with 2 metal gear 9g servo
Require your own motor, esc, battery, TX & RX to fly
SMS 9006 2589
Spec:
Wing Span: 1340mm
Propeller: 5x5-6x4
Weight: 510g
Condition is 7/10:
SMS 9006 2589
