WTS: KDS450sv FBL Kit + motor + ESC + Servos
    Hi Friends,
    Looking to sell my beautifully hopped up KDS450sv FBL as I am upgrading my fleet. I am breaking them up into items so as to make it versatile for you to buy.
    KDS450SV FBL kit ($200)
    1) KDS450SV kit with innova FBL Head (like DFC head) + beautiful Align tail fin
    2) Align 450pro V2 canopy + 2 original canopies
    3) KDS Heli Case
    4) Whatever spares for this Heli that I can find
    Add Mini titan 325mm CF main blades + Rotor CF tail blades ($30) &/or
    Add KDS-WS2838 Outrunner (upgrade) ($20) &/or
    Add KDS 40AII ESC ($20) &/or
    Add RCX MG9025 cyclic servos (new) x 3 + RCX MG9257 tail servo (new) ($100)
    Take all for $320
    Pls PM for enquires… I would appreciate self pickup...
ID:	990521Click image for larger version
ID:	990520Click image for larger version
ID:	990518Click image for larger version
ID:	990519Click image for larger version
ID:	990516Click image for larger version
ID:	990517Click image for larger version
ID:	990522Click image for larger version
ID:	990523Click image for larger version
ID:	990524Click image for larger version
    RCX MG9257 tail servo specs :
    Dead band: 0.002ms (Default)
    Control System: +Pulse Width Control
    Working Frequence: 1520μs / 80hz Digital mode/Analogy mode
    (RX) Required Pulse: 3.0~5.0 Volt Peak to Peak Square Wave
    Operating Voltage: 4.8~6.0 Volts DC
    Operating Temperature Range: -10 to + 60 Degree C
    Operating Speed (4.8V): 0.08 sec/60° degrees at no load
    Operating Speed (6.0V): 0.07 sec/60° degrees at no load
    Stall Torque (4.8V): 4.0kg.cm
    Stall Torque (6.0V): 4.5kg.cm
    360° Modifiable: NO
    Motor Type: Coreless Motor
    Potentiometer Drive: Indirect Drive
    Driver Type: FET
    Bearing Type: Dual Ball Bearings
    Gear Type: Metal Gear
    Programmable: YES
    Connector Wire Length: 18.0
    Dimensions: 35.5mm x 15.0 x 28.6mm
    Weight: 50g
    RCX MG9025 (Digital Version) Specs :
    Dimension: 22*12*29mm
    Torque: 2.5kg-cm @ 6V, 2.2kg-cm @ 4.8V
    Speed: 0.09sec / 60 @ 6V, 0.10sec / 60 @ 4.8V
    Weight: 15g
    Cable Length: 180mm(JR)
    Bearing: Top Ball Bearing
    Outrage Fusion 50 12S 6HV Head HC3-Sx; MSH Prôtos 500 6S mini VBar; SAB Goblin 380 6S HC3-Sx; MSH Mini Prôtos (Stretched) 4S mini VBar; Compass Warp 360 6S AR7200BX; Outrage G5 6S mini VBar;vWinRC 450T (Stretched) 6S HC3-Sx; mCPX; mCPX BL; DX8, Phoenix 5; RF7[/I]
      Originally posted by tsn1975 View Post
      hi bro..im interested on your servos..pls contact me @ 986 81990 thnx
          The servos are current reserved.
            The servos are sold...
            The ESC is currently reserved
              Heli, blades and motor still available.
