Hi Friends,
Looking to sell my beautifully hopped up KDS450sv FBL as I am upgrading my fleet. I am breaking them up into items so as to make it versatile for you to buy.
KDS450SV FBL kit ($200)
1) KDS450SV kit with innova FBL Head (like DFC head) + beautiful Align tail fin
2) Align 450pro V2 canopy + 2 original canopies
3) KDS Heli Case
4) Whatever spares for this Heli that I can find
Add Mini titan 325mm CF main blades + Rotor CF tail blades ($30) &/or
Add KDS-WS2838 Outrunner (upgrade) ($20) &/or
Add KDS 40AII ESC ($20) &/or
Add RCX MG9025 cyclic servos (new) x 3 + RCX MG9257 tail servo (new) ($100)
Take all for $320
Pls PM for enquires… I would appreciate self pickup...
RCX MG9257 tail servo specs :
Dead band: 0.002ms (Default)
Control System: +Pulse Width Control
Working Frequence: 1520μs / 80hz Digital mode/Analogy mode
(RX) Required Pulse: 3.0~5.0 Volt Peak to Peak Square Wave
Operating Voltage: 4.8~6.0 Volts DC
Operating Temperature Range: -10 to + 60 Degree C
Operating Speed (4.8V): 0.08 sec/60° degrees at no load
Operating Speed (6.0V): 0.07 sec/60° degrees at no load
Stall Torque (4.8V): 4.0kg.cm
Stall Torque (6.0V): 4.5kg.cm
360° Modifiable: NO
Motor Type: Coreless Motor
Potentiometer Drive: Indirect Drive
Driver Type: FET
Bearing Type: Dual Ball Bearings
Gear Type: Metal Gear
Programmable: YES
Connector Wire Length: 18.0
Dimensions: 35.5mm x 15.0 x 28.6mm
Weight: 50g
RCX MG9025 (Digital Version) Specs :
Dimension: 22*12*29mm
Torque: 2.5kg-cm @ 6V, 2.2kg-cm @ 4.8V
Speed: 0.09sec / 60 @ 6V, 0.10sec / 60 @ 4.8V
Weight: 15g
Cable Length: 180mm(JR)
Bearing: Top Ball Bearing
3) KDS Heli Case
Take all for $320
360° Modifiable: NO
Driver Type: FET
Programmable: YES
Weight: 50g
Weight: 15g
The servos are current reserved.
Heli, blades and motor still available.
