Hi all, I want to sell the following items! The pictures and descriptions show what you will get; please note!
1x Turnigy SK3 3542, 800kv motor
Link to motor here.
This is an approx 140g motor that was previously used in a 3D balsa plane (a 3DHobbyShop 47" SHP, then an Extreme Flight 48" MXS), but I upgraded the motor, so looking to sell. This motor is good to turn a 12x6 on 4S, or even a 14x8 on 3S. 3.5mm bullets pre-soldered on from the factory.
Example uses are for a 3D plane of ~1.3 - 1.4kg, or one of ~48" wing span. It tugs along the Extreme Flight 48" EXP planes along quite nicely.
Price: $20.
1x Hacker A30-16M V2, 1060kv motor
Link to motor here.
This is an approx 100g motor that was previously used in a 3D balsa plane (a 3DHobbyShop 47" SHP). Again, I upgraded the motor, so looking to sell. This motor is good to turn a 12x6 on 3S. You can go up to a 13x6.5 with throttle management and good cooling. 3.5mm bullets pre-soldered on from the factory.
Example uses are for a 3D plane of ~1.1 - 1.2kg, or one of ~42" wing span. It's a bit underpowered in a 47" SHP, though it still tugs it around the sky just fine.
Price: $40.
1x OKing Sbach 342, 863mm WS, indoor/outdoor EPP 3D plane
This is an indoor (but I usually fly it outdoor) EPP 3D plane. The unattached parts are in a ziploc bag and you can put them on if you want. You will need your own 4ch RX and your own 2S 450mah battery. I have... 6 packs, I think, but I can't find them right now . Otherwise I would bundle with this plane. Plane is in very good condition, minor crack on the rudder CF rod that I repaired. Perfect for learning 3D flight.
Price: $40.
1x HobbyKing Dual Storm indoor F3P plane
Link to plane here.
This is an indoor plane; it can fly outside but it must be dead calm. Fully assembled. It flies stupidly slow. You will need your own 4ch RX and your own 2S 300mah battery to fly. I wouldn't go heavier than 300mah because when I tried with 450mah I had balance issues. Plane has been flown maybe twice, it is in pristine condition. Not really for those wanting to learn 3D flight because it is made of EPS and will not take hits, but great for flyers who just want a light indoor plane or want to try their hand at F3P but don't want to buy and assemble a new plane.
I've built it with a 12A plush ESC, 2x HK 5g servo and 1x HK 9g servo on the ailerons.
Price: $40.
How to deal
Send me an SMS at ninety-eight, 24, nine thousand and ten. Please don't send me PMs, I do not check them regularly and I will not be able to keep your PMs in order.
All items are self-collect at my place in the east.
Thanks for viewing!
Link to motor here.
Price: $20.
Link to motor here.
Price: $40.
Price: $40.
Link to plane here.
Price: $40.
How to deal
Thanks for viewing!
