All items if used, are in very good and well kept condition.
1. Alloy DPS 72mm EDF 2250Kv Motor 1200W (Bench Tested Only) : $70.00
2. RC Lander Alloy 64mm EDF Unit with motor 4s (Tested & Fitted Only) : $56.00
3. CS 10 Blade 70mm EDF unit with L2855-2800 Motor Balanced (Used) : $30.00
4. Wemo Mini Fan 70mm with Het 2W20 Typhoon Motor (Tested & Fitted Only) : $70.00
5. CS 12 Blade 90mm EDF Unit (NIB) : $30.00
6. CS 10 Blade 70mm EDF unit (NIB) : $12.00
7. Turnigy L2855-2100 EDf Outrunner (900W) (NIB) : $10.00
8. 64mm EDF with Outrunner (Used) : $10.00
9. AX 1806C 2100Kv Brushless Micro Motor (NIB) : $10.00
10. D2830-11 1000Kv Brushless Motor (NIB) : $10.00
11. Turnigy Aerodrive SK3-2826-1240Kv Brushless Outrunner Motor (NIB) : $12.00
12. HK Red Brick 100A ESC (Opto) (Bench Tested Only) : $20.00
13. Hobby wing Pentium 60A ESC x 2pcs (USED) : $30.00 each
14. Hobby wing Pentium 30A ESC with 2040 Inrunner for 3s small 64 mm EDF (USED) : $30.00
15. Hobby wing Pentium 40A ESC (USED) : $20.00
16. HXT UBEC 5-6v Output, 5.5 ? 23v Input (NIB) : $5.00
17. Wireless Buddy Box System 4CH (Dual RX Controller) (NIB) : $7.00
18. HK Multi-Rotor Control Board V2.1 (Atmega 168PA) (NIB) : $10.00
19. USBasp AVR Programming Device for ATMEL Prccessors (NIB) : $5.00
20. Assan Adjustable Retract & Door Sequencer x 2pcs (NIB) : $10.00 each
21. Lumifly Lighting System FAA Configurable x 2 sets (NIB) : $8.00 each
22. HK GA-250 Mini ?Mems Gyro (NIB) : $10.00
23. D-MG16 Metal Gear 2.9Kg/18.8g servo x 5pcs (NIB) : $8.00 each
24. Turnigy V-Tail Mixer (Used) : $3.00
25. One Way Air Refill Valve (Air Retard) : $8.00
26. 300CC Air Cylinder (NIB) : $3.00
27. Micro Air Retract landing Gear Set (NIB) : $20.00
28. Wemo Bungee 5Kg with Hook : $30.00
29. Zippy 920mAh 2S1P 25C Lipo Battery x 2pcs (NIB) : $5.00 each
30. Single-action Fine bead blasting gun (NIB) : $15.00
31. SAPAC Br180 Wheel Brakes System (NIB) : $50.00
32. Pilot Figure (NIB) : $8.00
33. Plastic Air Retracts Medium (NIB) : $5.00
34. Plastic Air Retracts Large (NIB) : $7.00
35. 900Mhz 200mW Tx/Rx & 1/3-inch CCD Camera Pal 520TVL (Used) : $45.00
Interested parties kindly SMS or whatsapp me at 9O675574. Deal in Yishun thanks. Additonal Pics on request if not below.
