These are Atmel Atmega MCU Based ESCs.
1. Rated at 30A Constant
2. Fully N-Fet based (Runs coolest/best heat dissipation)
3. External Oscilloscope
4. Refresh rate up to 600hz (With SimonK fw) for better Auto-levelling/throttle response
(FYI in comparison DJI 30A Octos can only run at 400-450hz)
Since I will be flashing all my other ESCs with SimonK as well.. I'll be able to custom flash these for you specially.
Just let me know which config you want them optimized for Quad/Hexa/Octo and I'll take care of the rest.
I have 8 extra ESCs I'll let go at $25 each.
3S/5000mah. Fantastic Capacity/Weight Ratios!
Officially only weighs 354 grams. (But in-house testing I get around 359-371 grams)
Comes fitted with 5.5mm bullets rated at 120A
Brand New @ $50 each
Self collection in Tampines.
