Selling my rarely used 1/16 Mini Rally Extreme Edition with Drifting conversion kit included @ $120
Comes with Box & Manual
Had it for only about 2 months, thus Condition 10/10
Its PNP, just need your TX, RX and battery to run...
You can use your existing Plane or Heli TX & RX, not neccessary to get a Gun type (Car) TX or RX
PM me if interested...
Description
The Turnigy 1/16th Mini Rally Extreme is packed with features. Fully adjustable suspension such as front toe in and out, adjustable shock absorber locations and preloading, adjustable chamber settings, adjustable drop height, sway bars as standard and the list goes on! The Mini Rally Extreme has all the tunability of a car twice is size and double its price allowing you to truly customize the feel and performance of your ride.
The full time 4WD transmission is delivered blistering power from the 2040-4800kv Brushless motor and 25Amp Esc combination fitted as standard, no old school brushed junk to have to "upgrade" from here!
Aggressive styling, hot out of the box performance and real tunability are set to make this one of the hottest 1/16th cars to hit the streets in 2012!
Features:
Oil filled adjustable Shock absorbers
Anti roll sway bars as standard
Fully ball raced
Light weight glass fibre chassis
Tunable suspension geometry
Strong 15g Steering servo
Brushless power train as standard
Spec
Motor: Brushless Inrunner 2040-4800kv
ESC: 25A Brushless 2~3S (with Reverse)
Battery: 2S LiPo 1700mah to 2200mah (103x33x27mm MAX SIZE) w/ XT-60 connector (Required)
Servo: 15g Micro
Drive Train: Full Time 4WD, Twin Diff with Center Shaft Slipper Clutch
Suspension: Adjustable Oil Filled
Length: 325mm
Width: 180mm
Height: 122mm (With Body Shell)
Description
Features:
Fully ball raced
Spec
Servo: 15g Micro
Length: 325mm
Width: 180mm
