The CamOne infinity is the Full HD action sports camera for all your activities - due to its small size, its handy construction and a weight of only 77 grams. The extensive range of mounts allows you to attach it almost everywhere, e.g. to a helmet, a handlebar or a surf- or snowboard.
The built-in 1,5? (38,1 mm) screen shows the live image and informs about the settings and status. You can check your footage immediately on the screen. The ?EasyButton? system enables an intuitive use of the multilingual menu. Separate buttons for taking stills, recording a video and playing your footage as well as entering the menu and switching on the front LED ensure an easy and fast use of the camera.
You can record videos with 60 frames per second (fps) in 720p HD ready and 30 fps in 1080p Full HD. The camera is also capable of time lapse recordings and taking interval or serial photos which offers an exciting range of uses. Plenty of optional accessories allow you to customize the camera system to your personal needs.
With mounts like the Surf-, Chest-, or Curved Mount there are no limits for you and your CamOne infinity.
The camera has got two 32 GB Micro SD card slots, a mini HDMI and a USB port available. Using the USB port and the provided AV cable you can also watch your recordings on a TV screen. With the Ten2Ten adapter (also provided) you can connect the CamOne infinity with the complete range of FlyCamOne 720p HD hardware accessories: the radio transmission set, GPS, external screen and many more. You will easily succeed in making crystal clear videos under water. With the provided DiveBox you can dive up to 40 meters deep ? without any further accessories as the CamOne infinity can be adjusted to the light refraction of the water just by turning the lens counterclockwise by 95?.
The exchangeable lenses allow you to adapt to the picture detail you want. You can chose between 96?, 142? and 170? lenses. A scratched lens can easily be replaced by a new one.
HIGHLIGHTS
Built-in high resolution display
Full HD recordings in 1080p
HD recordings in 720p with 60 fps
Exchangeable lenses
Precise glass lenses
Easy Button System
Front LED
Auto power off, auto screen off
TECHNICAL DATA
Size: 49 x 42 x 34 mm
Weight: 77 g, incl. Battery
Operating-/Storagetemp.: 10 ?C till 50 ?C
Battery: 3,7 V 800 mAh LiPo
Format: MPEG4 or MOV (video); JPEG (photo)
Video Resolutions: 720p, 720pH, 1080pS, 1080p, Time Lapse (≤ 1 fps)
Photo Resolutions: 3, 5 and 8 MP
Functions: Photo, Serial Photo (3, 5, 10, 30, 60 s)
Sensor: CMOS, 5 MPix
Lens (exchangeable): 170? > 720p; 127? > 1080p
Zoom: Digital 4times
Screen: 1.5? (38 mm) TFT
Microphone: Mono, 48 kHz (built-in)
Ports: 10 Pin Mini USB 2.0, HDMI and Open Connector Board (OCB)
Remote (optional): Live view and control with smartphone and Wi-Fi connection
Memory: 2x Micro SD/SDHC ≤ 32 GB (Class 4 or higher)
White balance: Automatically
http://www.******et.org/Camone-Infinity.html
Interested Parties please leave a SMS.
9324 0050
