Asking $100.
Function 10/10, 100% New Battery.
Latest 2012 Maps loaded. Searching by postal code is now possible.
Dasboard/Windscreen Suction Cup Mount not available.
n?vi 300 Specifications
Moving map features
Storage: Internal storage comes preloaded with City Navigator? NT for street-level detail and addresses, plus listings of nearest restaurants, hotels, ATMs, etc., throughout the U.S., Canada and Puerto Rico, or a region of Europe (n?vi 300). Internal memory is available for supplemental maps, MP3s and audio book media from Audible.com. Auxiliary storage is provided by an SD card slot.
Map Scale: Screen-width scale 640 feet to 4,000 miles
Navigation features
Routes: Automatically calculated with turn-by-turn instructions; custom road preference allows user to prioritize choice of back roads or major highways; automatic offroute recalc shows how to get back on track if you miss a turn or exit; a detour function enables routing around traffic problems or road construction
Voice: Navigation instructions and warnings;
Waypoints: 500 with name and graphic symbol
Trip computer: Resettable odometer, timers, average and maximum speeds
Travel Kit Utilities
Features: MP3 player, audio book player (for Audible.com media), JPEG picture viewer, world travel clock with time zones, currency converter, measurement converter and calculator. Additional audio and content support is provided for optional Garmin Travel Guide and Garmin Language Guide software packages (sold separately).
GPS Performance
Receiver: (WAAS-enabled)
Acquisition times:
Warm: < 1 sec
Cold: < 38 sec
Factory reset: < 45 sec
Update rate: 1/second, continuous
GPS accuracy:
Position: < 5 meters, typical
Velocity: 0.5 meter/sec RMS
GPS (WAAS) accuracy:
Velocity: 0.05 meter/sec RMS
Interfaces: Proprietary Garmin through USB interface USB mass storage, plug-and-play
Antenna: Built-in patch; MCX-type connector for optional external GPS antenna connection
Physical
Size: 3.87?W x 2.91?H x 0.87?D (9.83 x 7.39 x 2.21 cm)
Weight: 5.1 oz (144.6 g)
Display: 2.8?W x 2.1?H (7.2 cm x 5.4 cm); 320 x 240 pixels; QVGA TFT landscape display, with white backlight and anti-glare finger-touchscreen
Case: Not waterproof or IPX0
Temp. range: 32?F to 140?F (0?C to 60?C)
Headphone jack: standard 3.5mm
Power
Input: 12/24 Vdc
Usage: 15w max. @ 13.8 Vdc
Battery life: 4 to 8 hours depending on usage
Moving map features
Navigation features
GPS Performance
Acquisition times:
Warm: < 1 sec
Cold: < 38 sec
GPS accuracy:
Physical
Power
Input: 12/24 Vdc
