HI all fellow flyers out there i am quiting the hobby. so got many items to let go so just sit back and relax on your seat and scroll down thru the post for all goodies.
ok this is how it will work..if you are interested in the item please reply in THIS SAME THREAD below with your contact number and the item number u are interested in this case every one knows when it is reserved and it it first post first get policy.this is how the system will work! if u are a fussy buyer or u want to come down for viewing or anything dont bother replying to the thread save everyons time. the format for example is: item number>>{ taking item 5}ur contact number>>>[contact:12345678}ur name>>{ mr x}note:lowballers f*** off
k lets move on to the stuff:
(1).cesssna 747 assembled kit with all servos installed and linked.(u can get it pnp from getting the esc and motor below)
condition 6/10 strenthned with pvc tape
going for $19
(2.)arc f-18 edf {bnf} comes with 3 good new batts and spectrum orange rx with satelite
condition of it 8.5/10 due to cosmetics.flem it a few times only.
Specifications:
70mm metal shroud using AVG 4200kv brushless outrunner and HET 6904 fan.
Electric metal retracts.
Hobbywing 100A ESC.
4 x Tower Pro metal gear servo and 1 x ACE RC servo
wingspan ~ 1m
fuselarge lenth~1.2 m
a great plane to fly and own. see the video review to know all about it
selling for $149(do the math and u know it is worth ur while)
(3.) spektrum dx 5e version 2 simulator port available.tx only!
used it for simulator only condition is still good see pics to belive.
letting go for $49 >>tx only no accessories.
(4.) 7 pcs of 9g servos. 3>>metal gear 4>>plastic gear
condition 8/10 cosmetics only.due to epoxy resedue on some servos only most are fine
letting go all for $9
due to some restrictions will upload the pic in the next post
(5.)64 mm duct fan unit only. no motor included
bnib
letting go for $8
6.)5 BRUSHLESS esc take all for $30 or the following
the exposed one without the ruber heat sink tubing>$2
axion 25 amp one is also>$2
the light blue and black turnigy fully soldered connectors are $9 each
the exposed 40 amp is >$9 need to heat shrink tube it.
(7.)2 brushless motor suitable for any gws planes or somilar all are 3.5 mm bullet connected
1 powerfull bruchless motor for fun jet or similar also bullet connected to 3.5 mm
specs:
1.tower pro 2408 1400kv brushless outrunner with prop saver plus free o rings>>$9
2.axn motor 2180 kv with prop saver as well>>$9
3.topband2815 brushless powerfull outrunner 3450kv suitable for fun jet new one.>>$4(include free cnc motor mount}
or take all the motors for $19
(8.)tower pro 18 a brushless esc. half bullet connected.
good condition
letting go at $9
(9) turnigy 30 amp BRUSHED esc for any brushed plane bnib
good use for any old brush planes
leting go at $9 only!
(10)turnigy hd flight video recorder.
great to use on any planes weighs only 19g
comes with accesories pack including adjustable mounts
need ur own lipo battery like a 1s 160 mah or 200 mah max.
just open the cover and put it in
letting go for $9 only
(11) WTG some props and a spare nine eagles gear set and also a pushrod set with rubber tubbing
if u need tit take it
free
thats just for now will post more later as for the pics post immediately
going for $19
Specifications:
Hobbywing 100A ESC.
wingspan ~ 1m
bnib
letting go for $8
specs:
good condition
letting go at $9
free
