Hi guys, the following charger related items are for sale. All come with what is shown in the photographs below. I have long since lost the various doodads that come with the chargers, but I have made each set usable with the necessary replacements. Reason for selling: I got a PowerLab 6 .
1x HKC6 for $5. Link for info. PSU required. I intended this to be part of my field charging kit but never got the chance to use it.
1x FAULTY iCharger for $10. Link for info. PSU required. This iCharger appears to have something faulty with the balancing function, but the rest of it works fine. For the past couple of weeks I have been using it to quick charge a whole bunch of packs in parallel, for which it works very well, and then finishing off the charging process with my other chargers. It just can't balance so not recommended for someone who needs a balancing charger, and who just wants a cheap fast charging device.
Also comes with the plug king 4mm banana plug - to - everything imaginable charging adaptor. Probably worth the purchase just for the adaptor alone, lol.
2x iMax B6AC chargers. $20 each. Link for info. Just plug these into your wall and you are good to go. These are both the "original" iMax chargers as HK likes to label them and have been my primary workhorses for some time now. One of them still has the US style plug because I hadn't gotten around to re-wiring it. Both can be used as field chargers also - I have included the necessary plugs.
1x NiMH/NiCD charger for FREE. It's what I used to charge my Tamiya cars. S$50 from Stargek before I knew any better . It is AC wall plug in, but the power cable is lost somewhere. It uses your standard computer power cable.
1x 9Ah Pb battery for $5. Small and compact, bring it around for your field charging needs. Hardly used, just plugged it in occasionally to help keep the battery chemistry happy.
Please SMS me at noine eighty-two four 90 ten to deal. Self collect at my place in the east after office hours is easiest. Thanks for reading!
