Extremeflight Extra 300S up for sale. http://www.extremeflightrc.com/html/extra300e.html
Repair done to motor mount with plywood and epoxy. Ripped cowl at front area. This is not an unflyable plane that i'm selling, i just flew it just now, tumbles, snaps, RCircles, hover, etc has no problem whatsoever. KE only need bout 2 click neg pitch koupling. Basically it performs every 3d maneuvers in the book.
My current setup:
EMP Outrunner BL Motor N3542/05 1000KV
12x6E prop (but need to replace. my wheel got stuck on a pebble and tip the nose over thus causing prop strike to the ground)
CastleCreation Phoenix 80A esc
HS65HB x 2 on ailerons
Emax 9g x 2 on rudd, elev
I'm running it on Voltron 3s 2200mah. (Not included)
Will include the unused wheel pants, prop spinner and 10x5 vox prop.
pics attached for yr reference.
Letting go at $150 only.
interested pls beep 90079327 Romi for enqueries.
This is not a plane for beginners. U can buy but keep it and only fly it once u moved to the next level...
My current setup:
