Dear gurus,
I have a 36" R2 Hobbies cat that I wanna built. Basically my cat looks like this with all the original parts.
This is what I intend to do.
a) Placing carbon fiber in the inner hull to strengthen it a bit,
b) 2 x Leopard 4074 or 4082 motors (How many kv to choose for a 4s setup)
c) 2 x Seaking 180 amps esc
d) 3/16 driveline with flex cables
e) Removal of the wooden plywood
Do you think this stringers will do? If not any other alternatives??
I think must get clockwise & counter clockwise whole set right?
Aluminum stinger 3/16" shaft for catamaran with cable set
[ASD014S] US $90.00
Aluminum 3/16" stinger drive for catamaran. Lead teflon bushings inserted. Stinger angle adjustable. Silver anodzied. Sold as per pair (2 unit).
This complete set come with;
2 x Aluminum 3/16" stinger drive for catamaran
2 x 480mm long brass tube with teflon lining
1 x 3/16" left lay cable with stubbed stainless steel shaft 500mm long
1 x 3/16" right lay cable with stubbed stainless steel shaft 500mm long
2 x stainless steel prop nut
2 x stainless steel drive dog
Would this couplers do??
Specs:
5mm motor x 3/16 flex collet
$15.00
5mm motor, 3/16 flex
30mm long
plus
5mm motor x 3/16 flex collet Reverse
5mm motor, 3/16 flex 30mm long For clockwise spinning motors
Any idea what kind of motor mounts to get as I understand theres very little room to work with twin motors in cats. Appreciate if you could show a link to the available types of motor mounts.
As for props, I don't know how to sharpen or detounge ......... so should I go for carbon ones????
Such as Graupner carbon & what size (mm & pitch) should I choose???
Appreciate all your responses.....
& What kinda speeds can I be looking at........... hehehehe
& lastly what else should I be shopping for to complete this boat.....
[ASD014S] US $90.00
Specs:
$15.00
30mm long
plus
