Originally designed by DemonGti from rcgroups. This is my 2nd build. Had maidened her last sun and decided to finalize on the decals. Maidened went smooth but some fine tuning needed. Need to add a bit of up thrust on the motor and need bigger capacity batt. currently using 1850mah 35c and got only bout 3+ mins mix flying. gunning for 2200mah next.
parts are 6mm depron sheets, plywood and carbon rods.
setup:
EMP Outrunner BL Motor N3542/05 1000KV
CC Phoenix 80A (Overkill but thats the only esc i have sufficient for the motor and does the job good)
Voltron 1850mah 35C 3S
hxt900 x 4
JXF 12X7 prop
AUW is at 940gm +30gm if i use 2200mah
Very stable at extremely slow flight. Easy to hover at half throttle with curent setup. Would definitely recommend intermediate--->advance pilots to try it.
original build thread located here
setup:
hxt900 x 4
JXF 12X7 prop
