I wld like to convert my Proboat Volere EP 22 to brushless, but need some help in finding right motor and ESC. Hope you guys can offer me some advice.
The boat is only 22 inches. It?s a classic wooden speedboat, so it?s obviously not for racing/high speed. I do want it to run faster than stock though.
Someone did a successful conversion on YouTube. Here?s his video to give you an idea of what I mean:
So I basically need a 540 brushless motor, and I want to use just a 2S (7.4v) lipo.
I saw this motor on Dealextreme and I wonder if you guys could tell me whether it?s a good enough for the boat in terms of speed and power:
Is the kv too high? Shld I go for lower KV like this one?:
Another question I have is that the stock motor is water cooled by a coil and I would like to use back the coil. But seeing that the above brushless motors have cooling fins (i.e. not typical smooth surface), will the coil still work since there's less contact surface? Here's a pict of the stock motor and cooling coil:
Thanks for any help and advice. If you have better motors to suggest, pls tell me. tks!
