Scratch Building - Guppy Variant - some pictures
    I am scratch building a variant of the Guppy Sailplane.
    here, take a look at some of the build pics
    it is a Guppy microsloper foam core wing variant
    just something to occupy my time....
Name:	2012-04-25 09.51.13.jpg
    wing is designed as a 3 piece wing with small midsection. reason for it - I have closed a car door on a balsa kit build before. Should have been more careful, but oh well, my build, my style
Name:	2012-04-25 09.51.33.jpg
    plank bottom side then cut out the cavities for wiring then plank top side\
Name:	2012-04-25 21.56.59.jpg
    top side
Name:	2012-04-28 22.21.51.jpg
    test fitting unplanked foam wings
Name:	2012-04-28 23.52.49.jpg
    more of the center section
Name:	2012-05-01 21.52.48.jpg
Name:	2012-05-03 10.36.37.jpg
Name:	2012-05-06 12.58.03.jpg
Name:	2012-05-13 21.32.59.jpg
Name:	2012-05-13 21.34.16.jpg
    dihedral wing, 6 degrees
    very nice! what size is the wings?
    Fubata 7C 2.4 + T6XAs
    Charger- Turnigy AC6
      Yeah.. asking the same.. going to be 4m?
        or 5m
        Share the joy of flying . . .
          1.45m small small only la
            more pictures 4u2c
Name:	2012-05-25 00.54.30.jpg
Name:	2012-05-26 09.52.32.jpg
Name:	2012-05-26 09.52.41.jpg
Name:	2012-05-26 16.50.27.jpg
Name:	2012-05-26 17.23.51.jpg
Name:	2012-05-29 09.04.15.jpg
              oh shucks I forgot to resize the photos
              cos RCgroups auto resize for me.
              erm, how ah
                erm, how ah
                Doesnt matter. not much of a hassle.
                "For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return." - Leonardo Da Vinci
                  erm, how ah
                  nbrmnd la.. my screen quite wide.. still can contain them :p
                  maybe next time you do a 4m then my screen cannot tahan liao..
                    a bit moar updates
                    I have decided to ditch the T-tail and go for conventional tail
                    but that's not in this post
                    build the canopy plug out of balsa
Name:	bubble canopy1.jpg
                    buy PET sheet, tape over the canopy plug as tightly as possible
Name:	bubble canopy 2.jpg
                    use hairdryer, heat until floppy, and use oven mittens to press to shape. trim off excess
                    referred to Joe Yap's instructions on how to do canopy
                      did up the wing hold downs
Name:	2012-06-02 12.02.42.jpg
                      glued in carbon boom. using gorilla glue. use lines in floor tiles for rough alignment
Name:	2012-06-05 22.59.34.jpg
Name:	2012-06-05 22.59.56.jpg
                      tail assembly
Name:	2012-06-05 23.01.04.jpg
Name:	2012-06-05 23.03.17.jpg
                        next, comes the really hard part.
                        seal wood with this
                        apparently its a alternative to varnish.
                        I chose it because well....it was for aircraft
                        seal, sand with 400 sandpaper, paint over another layer, sand again, lay on glass, sand again,
                        spray paint grey primer, sand again with 400 till smooth, spray on yellow paint, sand with 400, spray on multiple layers of thin yellow, sand with 600 then 800....
                        then FINALLY you get a glossy sheen.... phew
                        the next steps are pretty straightforward, covering with lightweight covering. I used the Japanese label ones from SHS. Point to note, they are easier to handle than lightweight Coverlite because they do not have a backing and thus the sticky side does not stick to itself
                        Oracover trim is used to give a bit of contrast
                          anyway I've set up the linkages late last night
                          so it's off to fly it today = )
                          Mr James Lee was the witness
                          it flies!
                          today was a day for thermals. I had 10 minutes of flight on this. Just follow the swallows
                          and after that, you pack up
                          it is not a one piece wing
                          some data;
                          span: 1.45m
                          length: 80cm
                          weight: 370 gms (heavy)
                          wing area: approx 300 sq inches
                          wing loading: 6.25 oz/sq ft
                          wing cube loading: 4.3
                          servos: 4.7 gms from SHS for ailerons
                          2 x tp 6gm for elevators and rudder
                          motor: google this: AX1806c from HK
                          ESC: HK12amp
                          battery: 2s 450 nanotech
                          boy, I'm tired of scratch building. Maybe I'll get an ARF next....just maybe....
                            Nice
                            Well done bro!
                              Meow..
                              You got a meow at home ah?
