Is there any way to mount a prop saver on the front of this motor(Note the picture is from the net and is only for illustration purpose) ? The shaft is a threaded shaft. I know that the correct way is remove the front threaded shaft and then reverse the inner motor shaft. However, my motor does not allow shaft reversal.
Thus, does anyone know of a way to mount a prop saver system on this kind of threaded shaft? Or a prop saver system without reversing the inner motor shaft?
Thanks in advance.
