Decided to let this go after letting it sit at home for so long. Realised I prefer something lighter. Ultra low mileage. You can tell from the tires ? they?re almost brand new! The usual scratches on the body, bumper and skid plates are from doing some test runs and back flips at the badminton court and on the grass patch. Never tracked before.
Took tonnes of pictures. Posted at .
The following is an extensive list of what you?re getting
HPI Savage Flux HP with Flux Tork 2200kv Motor and Flux Blur ESC
Additional motor cooling fan installed as shown
Chasis & Suspension Modification
Fast Lane Machine Heavy Duty Black TVP chassis
HPI Racing Suspension Conversion
HPI Alu Big Bore shocks (35w silicon oil filled)
HPI Big Bore Springs Red
HPI Anti/Sway bars set
Lundsford Full Titanium turnbuckles & hinge pins conversion
Steering / Electronics Modification
Savox SC1256TG titanium 20kg steering servo
Dynamite Alu servo horn
HPI Steering ball bearing set
HPI Heavy duty spring for servo saver
Fast Lane Machine Heavy Duty Steering plate
Toplakd Heavy Duty Suspension Braces Frt & Rear
Motor & Drive train Modification
HPI Heatsink heavy duty motor plate
HPI Heatsink heavy duty motor mounts
HPI Heavy duty drive gear 18-23tooth
Hotbodies 23T pinion gear
Tires and wheels modification
HPI Wide wheelbase axle conversion
Team associated 17mm wheel hubs
Hotbodies 17mm wheel lock nuts
Proline Masher 2000 3.2 tires
RPM Revolver rims black
Body
Proline Chevy C10 body shell (painted orange. Show piece, no scratches)
Original body shell (for bashing, usual scratches)
Others
Rcscrewz full stainless screws kit
Plus all the spares you see in the pictures
2 of the 4 batteries you see in the pictures
Original manuals and instruction sheets as shown
I?ll also be including 2 x 2s batteries in the sale (choose any 2 you see from the pic) since I won?t have much use for them anymore. Each of the packs has less than 3 cycles through it. Well kept and storage-charged for longevity.
Last I checked, the price of the basic model at Tai Seng is already S$1,399. Option parts you see here will cost over S$1000 easily. All yours for just S$1,000 (firm). Willing to hear alternative offers if you think this is not the right price but no low balling please.
Test drive? I can even power up and show you before you take home the truck. Still got a receiver plugged in there for the time being.
ARTR condition. All you need is your own Tx and Rx to start enjoying truck. It?s that simple.
PM / WhatsApp / iMessage to 9756-7686 / jcdeme@gmail.com
Body
Others
