Hi Guys some planes for sale or trade.
1) FMS F-16 (Tiger Scheme) 70mm Ducted Fan PNP (Got it from Jet Hobby) - jus plug your receiver and batt to fly. (running on 4s 2200 batt) Note had a broken nose due to a crash but repaired and does not affect the flying. Very floaty plane. $110
2) F4J-II Phantom - 64mm fan, 4800kv topband motor, 60amp ESC(hobbywing), 3 Turningy servos. Flying on 3s 1800mah - 2200mah batt. Had a nose break but repaired and very gd to fly. Removed landing gear for belly landing. Smooth to fly, smooth to land. Jus add ur receiver and batt to fly. Asking for $80
3) Zero Fighter – FSD 1250kv motor running with master airscrew 9x6 prop, 40amp Tower pro ESC and 3 servos (2 of them are metal gear servo for elevator and ailerons). Wingspan about 900mm. Flying on 3s 1300mah batt. Crowling break due to a few hard landings but taped it with fibre tape, can easily replace new crowling so not much issue. Some dings and dents from flying and belly landing. Jus add ur receiver and batt to fly. $60
4) Mirage 2000 (Lan Xiang) – 64mm fan, 4800kv topband motor, 40amp tower pro ESC, 2 servos. Flying on 3s 1300mah – 1800mah batt. Removed landing gear for belly landing but there is still a servo inside for steering nose wheel so there are 3 servos in the plane but 1 for steering nose gear not in use. Had a few crash on it due to pilot mistake, wing break, nose break. Flyable condition quite floaty too, easy to land. Repaired and also touched up with paint so still looks fine $60
5) T-38 Talon (Freewing) – 64mm fan, 3500kv topstar motor, 60amp ESC, 2 metal gear servo(ele, aileron) Cut to fit 4s setup. Very smooth and stable plane and floaty. Flying on 4s 2200mah, removed landing gears for belly landing. No crash on it yet haha. 4s provide more thrust power, easy to launch and recover when flying. $100
Pls sms me at 90290951 to discuss. Thanks!
