Plane only and EME35cc engine - S$500.
The plane is in good condition. No crash. Only repair is to the undercarriage which have been strengthened after a rough landing at Punggol field because of water ponding.
The EME35cc is pretty new and is more than enough power for this plane. Starts easily.
The plane cost around S$480 and the EME costs around S$340.
Deal in Pasir Ris. Contact me at nine-8-0-0-6-1-5-nine. Thanks for viewing.
_____________________
Specs:
WING SPAN:76”(1930mm)
LENGTH:74”(1879mm)
WING AREA:1200sq in(77.4sqdm)
FLYING WEIGHT:9.9-12lbs(4.5-5.5kg)
Glow:.120-170
Gasoline:30-40cc
Electric:AXI 5320-5330
RADIO:4CH/5-6 servos
Description:
Oracover flim;
Carbon Fiber:Wing Tube, Tail Tube, Landing Gear, Tail Gear;
Fiberglass servo arms and horn;
Canister Ready Tunnel;
Adjustable pushrods;
Ringed Cowl;
Pre drilled hinges;
Removeable Wings, Stabs;
pics: http://www.aeroplusrc.com/Demo_showP...asp?ProID=1773
Specs:
LENGTH:74”(1879mm)
Glow:.120-170
Gasoline:30-40cc
Description:
Oracover flim;
Ringed Cowl;
Pre drilled hinges;
