If you constantly plug in and out regularly from the balancing lead for charging you may notice that one or two of the wires may pop out and comes loose. This is annoying as the charger will beep due to open circuitry and proper charging will not be carried out. Put some epoxy on the 'sensitive' areas and not only it will extend the life of your balancing cables it will also not irate you any further during charging sequence. Preferably, do it for both ends and your balancing leads and balancing extenders as well, if any. If you dislike the 'epoxied' look you can put a bigger heat shrink over it for aesthetics.
