Hello everyone!
photo from: http://******etpuss.******et.netdna-...nshot_6-05.jpg
A/C Manufacturer's Website: http://www.finwinghobby.com/product_view.aspx?id=4
Foreword:
- I am obviously not sponsored by finwing.
- This is just a build log not meant to get anyone insanely hooked onto FPV and diving into something which you'll regret later.
- The A/C is huge. tip to tip wingspan is almost my height (im 177cm) at 1.7meters, so i hope you know what you're getting yourself into if you choose to get this.
- Shipping is hellish expensive, but the seller is awesome (which is why I am writing this to complement him for his professionalism).
Points to note:
- This would be a summarized build log with rather long paragraphs of text.
- I DO NOT follow manual throws and expo settings, i normally set max throws on all my control surfaces and expo them to 30%, and change from there =).
- I have not and will no do long distance fpv, although this platform is perfectly capable of doing so.
- There will be updates and upgrades in the future.
So. Why the penguin V2?
Because i liked it, and i really think that its a legit platform which can expand due to it's huge storage capabilites.
Why not the bixler like everyone else?
*like everyone else* and i just simply didnt like the look of the bixler. the penguin with the weird bubble canopy removed looks pretty badass. and it can carry a gopro with ease!!!
Will i ever recommend this to anyone in singapore?
No, HAHA actually yes =) although it comes in a pretty big box, and it kinda hangs its tail when it turns, its a really forgiving aircraft. And i would say an awesome fpv platform because of its large wing area and its super stable gliding characteristics, maiden'ed at OHR and i actually preferred gliding compared power flights (maybe because my thrust angle is screwed)
Please note that you need to have space for an aircraft this size!!! I was lucky that the fuse can even fit in my room!
A/c manufacturer's notes:
Wingspan: 1720MM/67.7inch
Length: 1230MM/48.5inch
Wing Area: 36dm/3.9ft2 (Mainwing Area)
Motor: Brushless motor M2220 or M2815
ESC: 40A for M2220 or 60A for M2815
Servo: 3pcs 17g servo+ 1pcs 9g servo.
Battery: Li-Po 11.1V 2400 mAh for M2220 and 5000mAh for M2815
ARF Weight: 0.98kg/34.6oz.ARF is the weight including almost ready to fly, not including battery and your extra FPV devices
Max.flight weight more than 2.4kg (mine measured out at around 1.8 to 2kg)
Payload: 600-1000G/21.5-35.5oz (Payload is the extra weight it can carry besides the standard ARF weight)
Material: EPO Wing and fuselage/ Wood reinforcement/ aluminum alloy Pipe/Carbon Fiber Tube
More Pics and build notes coming soon.
Foreword:
Points to note:
