Selling SBACH342 55in (Hokusei RC designed)
    This plane is designed by Hokusei RC, and sold under the AD Aircraft brand outside Japan.
    Plane only (no motor, ECS or servos) at $200.
    Also selling Dualsky XM4250EA-8 560KV (for use with this plane with 2x 3S2200mAh battery, ie. 6s). Price for motor is $50.
    Also selling Dualsky XM4250EA-6 745KV (for use with this plane with 4S3300mAh battery). Price for motor is $50.
    Buy the plane and ONE motor (your choice) for $230.
    Selling because got new project. Plane is in very good condition. Only had 4 flights with it during maiden. This is a 3D plane that can do all the 3D stuff, harriers rock steady, elevator is effortless, hovers well, knifeedge is incredible, goes into knifeedge spin so easily, etc. Just check out youtube videos (search for hokusei rc sbach55 & you will see what it can do in the hand of an expert).
    You will need 4 Hitec HS225MG and a 60A ESC and the above motor and 14x7 prop.
    Spec from web-site:
    Wingspan: 1,400mm (55in)
    Length: 1,350mm (53in)
    Weight (w/o battery) : 1,815g and with battery 2,195g
    Recommended motor: Dualsky XM4250CA-6 KV840 (for 4S3300mAh) or Dualsky XM4250CA-10 KV510 (for 6S2200mAh)
    ESC: Dualsky XC6018BA-V2 60A  or HobbyWing  PLATINUM-60A-PRO
    Battery:4S 35C 14.8V 3,300mAH
    Propeller: HS 14x7E
    Call/sms me at 98006159. Deal or view at Pasir Ris.
    Thanks for viewing.
    Pics
    Pics
      up +1
        Sold
