KM baja
    KM baja
    KM baja
    Tachometer Trail Tech TTO Tach/Hour Meter (20,000 RPM)
    Hostile REAR 5b Zero Growth Molded Foam Inserts – Hard
    DDM Stainless Steel Beadlock Bolts (Set of 84) for HPI Baja 5B/5T
    TGN Easy Clearance Air Filter for HPI Baja 5b/5T
    Tall Velocity Stack ORANGE
    Copper Gasket for CY Headkits
    .020" (0.50mm) Copper Cylinder Gasket for RC Engines
    .040" (1mm) Copper Cylinder Gasket for RC Engines
    DDM "Black Magic" 6v Ni-MH 5000mAh Hump Receiver Battery Pack for HPI Baja
    Billet Pull Handle – ORANGE
    Top engine CY billet Headkits
    15:1 Dome for CY Headkit
    Silicone Spark Plug Cap
    Snappy RC Superior eClips for HPI Baja 5B/5T
    Hostile Plastic Spur Gear - 55T
    Shaft Clip Set 6mm for FG Marder/Leopard/Baja
    High Response Clutch Spring Set
    Pinion Gear Heat Sink
    Team FastEddy Replacement Sealed Axle/Clutch Bearing for HPI Baja 5B/5T
    Biohazzard Gas Cap – ORANGE
    Venom Micro Temp Sensor
    Snappy Tire Caddy
    RC-Skin Shock Covers – Orange
    DarkSoul Steel Bumper for HPI Baja 5b
    FF Front/Side Windows Orange
    Pro-Line Undertray for HPI Baja 5b
    Pull Start Cover - OW Orange
    Xcan Black Tube Set
    Dually Silencer for Jet-Pro V3 HPI Baja 5B/5T
    OW Crankcase/Flywheel Cover – ORANGE
    Outerwears 3 x 2.5" ORANGE"
    20ml Bottle of Air Filter Oil
    TGN 'Redneck' Dual Stage Pre-Filter for HPI Baja 5B/5T
    Hostile Gear Set - 19/55 Tooth
    Velocity Stack Gasket
    Hostile MX Knobby Tire Set (EXTRA HARD Compound)
    Intergerty CARBON disk break
    with the above .....
    $700
    96747117
ID:	974383Click image for larger version
ID:	974384Click image for larger version
      with one more NEW set of rims and off rd tires ( tatal 8 rims and 12 tires )
        Withdrawn fm sale
        Thanks for the interest
