WTS Parkflyer Buttercup
ups, great plane for learning to fly.
Well balanced master airscrew prop using sanding method for smooth minimum vibration high speed rpm. Prop hole is drilled precisely to fit prop adapter, there is no plastic shims in prop.
Removal wings using two screws
Precision pin for locating wings for every assembly and removal
Proper light weight servo trays for reliability, servos are not taped on but secured on with two screws.
Wheels are fitted with sleeve bearing for smooth taxi.Scratch building is more than cutting balsa wood and gluing them. Its a complex process that will test even the most resilient of people
