This is my second Logo 500 (with carbon tail). I have a few incidents with the push rod tore and lost control of the tail completely. I managed to bring the heli down safely with auto in two of the incidents but not the last one. After many days of effort, I found the cause was due to tail rotor shaft heated up to high temperature, and this was related to the carbon belt tensioner length. The carbon belt tensioner consists of one bearing (4mm thick) an two pvc sleeves (9mm each). This will give a total length of 22mm, same as the length of the tail hex bolt. However, what I found was the actual length of the pvc sleeves is only 8.7mm. This means the total length of the tensioner is only 21.4mm instead of 22mm. Because of the 0.6mm short, additional pressure is put on the bearings (on the tail rotor shaft). And this extra pressure caused the bearings to heat up itself and the tail rotor shaft. To solve this problem, I add a 0.5mm washer between the vertical CF fin and the pvc sleeve (see picture below).
