It finally happen , pu tit down today due to dumb thumb. Trying to pull up after inverted flying then loss visibility as I got too low and pull the wrong direction.
This is a super flying glider and it will thermal forever due to its weight.
I know it can be fixed , just like I have two more gliders coming so I letting this one go. Am looking at offer.. ;
You should also be able to get spares through APACHobby if you need or want a new fuselage..
Servos :
- flaps :- A7030 HV Thin Wing Servo X 2
- Alierons and Vtail :- Tahmazo TS-1014 9mm Servo 2.0KG/0.16S. X 4 ( one of them on alieron need to replace as the gear strips )
As close to 50% of a new kit is what I hope to get.....but will listen to offer..
Here is what it looks like new
regards,
Jonathan
Servos :
regards,
Jonathan
