Raketenwurm 4B
Originally posted by Hawkeye View PostI did not plan for everything to arrive at the same time but oh well. Delivery schedule is dodgy at best. This will be next on the build list after the Fireworks.
Some really nice looking planes man!
-Jonathan
Jonathon,
No complains from the wife......"yet"..........she recieved both packages on my behalf and paid GST:wink5:
As long as I dont compete with her for the dining table bewteen her baking and my building there is peace at home.
Mooncakes and CA dont mix very wellDo you feel the RUSH....!!!!
More work done on the 4B
Since the nose is removable, I had to install a blind nut on the nose. A matching hole in the fuse allows a 3mm screw to lock onto the nose.
The NACA inlet was then cut, epoxied from the inside reinforced with carbon cloth.
The RW4B has a slightly shorter nose of about 15mm and a longer tail of 30mm. As you can see the wing saddle side by side with the old plane, the Naca exit and Chps plug is further back allowing for longer battery packs.....A 5S2S to be exact.
You build a tongue out of thin plywood and reinforce it with glass fibre tape
Than you use kapton to wrap the BEC, BEC battery and RX and also all the cables etc in a neat package and slide the whole assembly into the rear of the fuse with the tongue long enough so you can push and pull on the whole module from the wing saddle opening.Do you feel the RUSH....!!!!
