Build log: Mini Ugly Stick - hopefully this flies
    It's a bit embarrassing as this was supposed to be an example of a quick build and my attempt to actually fly what I build.
    A wise flier told me to keep it simple, and not complicate the build, not to mention something easy to fly.
    However, it's nearly a year now and I haven't completed the darn thing! (just looked at the photos and the dates on it)
    So, here it is and probably no need to mention where the kit came from (and how cheap it was)....
ID:	984887Click image for larger version
    Hey man,
    May I know where you got this kit?
    Cheers,
    Adnan
      Originally posted by randomtask View Post
      Hey man,
      Cheers,
      Adnan
      It's that site where the initials / abbreviation is the same as the country it's from.
      If you Google it, am sure it will show up as well.
        Kit came slightly damaged but nothing a little glue wouldn't solve.
        Also decided to try using white glue / PVA instead of CA.
        Never had the patience to try so, why not....
        Some test fitting of the parts without the glue.
        Note, no plans or instructions came with it.
ID:	971830Click image for larger version
ID:	971831Click image for larger version
ID:	971832Click image for larger version
          Overkill on jigs, on building this jigsaw type fuselage.
          Reminds me of the Pilot / OK Models kits....
ID:	971834Click image for larger version
ID:	971835Click image for larger version
ID:	971836Click image for larger version
ID:	971837Click image for larger version
            And the fuselage sides:
ID:	971839Click image for larger version
              And the wings.
              This white glue thing is quite something if you have the time and patience.
              Am learning....
              Test fit and it's looking good. Needs some tweaks for a better wing fit. And on to sanding and no point getting pictures of that.
              Will get back again once the linkages are tested, and there's some progress on covering.
ID:	971841Click image for larger version
ID:	971842Click image for larger version
ID:	971843Click image for larger version
ID:	971844Click image for larger version
                I bought 4 of this kit and my student built one of them. It didn't fly but it was mainly due to his workmanship.
                  Thanks Joe... this really helps my confidence of getting something simple back in the air.
                  How did the plane turn out?
                  Just spent a little time fitting the wing and tail.
                  Am going to use your suggested hinging method with the covering.
                  http://www.daddyhobby.com/forum/show...l=1#post449246
                    Glad to see that you are still building and it looks good. Love those clamps and jigs
                      Clamps and jigs
                      Hi, may i know where to get those clamps and jigs?
                      Thks
                        Hey Chin Poh, yes... trying to finish this ultra simple kit but just fighting other priorities. Inspiration's not necessarily there either given the type of plane. Anyhow, need to get something in the air soon. Am already sure the my currency is totally off!
                        Eekin, the blue clamps were from Carrefour but haven't seen them lately. I have seen them in DIY stores, and a friend gave me some small clamps. The stores probably have the larger ones. If I come across them again, I'll put a post up for you. The yellow clamps were from a hobby store in the US.
                          David
                          I think that is a good plan. Finish it off quickly and fly it. The Ugly stick is a good and capable flyer.
                          We lost our flying site at Tanjong Tokong. These days we fly off Polo Ground. The old gang is still intact.
                          Regards
                            Hi Mr Yeap,
                            Haven't hear from you for a long time! How are you doing?
                              HK is selling those clamps
                              Thks
                              Bro, HK is selling. http://www.hobbyking.com/hobbyking/s...wer_Search.asp
