ROBIRD G31 FBL System released!
This topic is closed.
Originally posted by mh3400 View Postis there a restriction of using certain RX ?
i know only servos must be digital. How about RX ? sorry might be dumb question to ask
DSM2/DSMJ/DSMX has the privilege to use Satellite options supported by the G31 for JR and Spektrum owners.
3 connection types:
1) PWM (your normal receiver connections)
2) S.BUS (for those receivers with S.BUS)
3) External Satellite via SRX cable provided
SKY HOBBIES SINGAPORE
Tel : +65 6293 3968
Website:
Official You Tube Channel
FACEBOOK :
Originally posted by mh3400 View Postany recommendation on the throttle curve and pitch curve for beginner ?
do i still adjust the pitch curve to what i needed on the Tx ? and also for the throttle curve.
or i leave the throttle curve and pitch curve as straight line on the Tx ?JR9XII PCM 72.xxx n XPS n FRSKY 2.4GHz
me is " Kancheong spider "
Originally posted by mh3400 View Postwhat i meant is after doing the +-12 and cyclic +8.
Please note : Cyclic Pitch and Blade Pitch is different...
Cheers!
Tel : +65 6293 3968
Website:
FACEBOOK :
Originally posted by eagle51 View PostI just bought today g31 and im planning to setup for raptor30 and i found out it is not compatible because left and right arm of the swash is using one servo. it is meant for ccpm only.
Thank you for your support for G31.
Current swash types are for eCCPM & CCPM. However Robird just reverted that they are currently finalizing the mechanical mixing swashtype in their next firmware update to be released in a couple of weeks. The next update will include governor parameters together with the additional swashtype that were not included in your case.
Please note that your TT Raptor 30 is currently a flybar helicopter as they did not have FBL since their release about 12 years ago. It highly recommended that you make a full conversion to a full-fledged FBL Rotor head for G31.
Cheers and regards
Derrick
Tel : +65 6293 3968
Website:
FACEBOOK :
