my current setup is as follows,
Hardwares,
mill - sherline 2010 cnc ready
pc - old P4 laptop (changing desktop soon)
axis card - xylotex 4 axis driver board
stepper - Kelinginc KL23H256-21-8B Bipolar, 8 wires
power supply - 24v, forget how many amp, but at higher side
use the 9pin connector for easy connect/disconnect of stepper motor.
software,
Mach3 (G code processor)
bobcad-cam (drawing/gcode generate)
using parallel port between pc and axis card.
if you are good at soldering, can consider the HobbyCNC axis board,
which comes in a kit form. more work but its a lot cheaper.
also parallel port. was using this while my xylotex was down.
actually, mostly taken from Mike's advices
still can not really compare the axis cards yet, too little cutting time.
was lucky i manage to cut the above project, just realised one of the
"nut" was out of place all these time.
stupid me was fooling around sometime back and dis-engage the x-axis
table by moving too far out.
Hardwares,
software,
