DJI SPARK Portable Charging Station COMBO with bag and 2 x Batteries
BRAND NEW Impulse buy! Special Xmas offer, cheapest in Singapore!!
Asking for $210 for ALL items, charging station, 2 batts and original spark charging station carry bag!!
The usual price is over $250!! Items are BRAND NEW.
Overview:
The DJI Spark Portable Charging Station is designed to wirelessly charge up to three Spark Intelligent Flight Batteries on the go. Safe and intelligent with an impressive total power of 5000 mAh, the Charging Station charges up to three Spark batteries in 2.5 hours when fully charged. It also provides power to mobile devices via its USB port, and the Charging Station itself charges in just 1 hour and 35 minutes.
To charge Spark with a battery inserted, just put the aircraft on the charging contact in the Charging Station. Battery slots on either side of the Charging Station let you charge up to two additional batteries. When charging, the Charging Station will first charge the battery in the aircraft and then any extra batteries according to their power levels from highest to lowest.
Highlights:
High-capacity mobile charging station that's great for traveling
Charges up to three batteries for up to 48 minutes of flight time
USB port provides power to mobile devices such as smartphones and tablets
Adjusts charging current automatically according to temperature
Convenient for storing the aircraft and batteries when not charging
In the Box:
Portable Charging Station × 1
Charger × 1
Power Cable × 1
Specifications:
Model: MMPCS01
Compatible Battery Charger: Spark Battery Charger (F1C50 Version 2)
Compatible Battery Model: MB1-1480mAh-11.4V
Output USB Port: 5 V, 2 A (Total)
Real capacity: 4200mAh (built-in 5000 mAh battery), 54 Wh.
Weight: 680 g
Input Voltage: 13.05 V
Input Current: 4 A
Operating Temperature Range: 41–104°F (5–40°C)
Charging Time Connected to an external power source:
Approx. 1 hr 35 min (station only)
Approx. 3 hr (station and three batteries)
Disconnected from an external power source:
Approx. 2 hr 30 min (three batteries)
Compatibility:
Spark
Spark Intelligent Flight Battery
Interested please sms 91111933
Overview:
Highlights:
In the Box:
Charger × 1
Power Cable × 1
Specifications:
Model: MMPCS01
Weight: 680 g
Input Current: 4 A
Compatibility:
Spark
