T37 Twin Charger doubles the power with dual output for both independent and simultaneous charging and discharging.
T37 Twin charger incorporates the latest charging software that will
improve the charging and discharging time,
optimises the battery performance by its new charging algorithm and system,
displays the charging and discharging system via USB port
T37 Twin charger has 2 independent and simultaneous charging and discharging port, and the input power for each channel can also be programmed.
Other features include:
40 memories for storing battery parameters
Able to charge and discharge NiMh, NiCd, LiPo, LiIo, LiFe and Pb batteries
Automatic charging, discharging and other conditioning programmes for the various type of batteries
Easy to operate with 6 clearly marked buttons
High contrast LCD screens with adjustable contrast levels
Delta-peak cut-off detector for NiMh and NiCd cells with variable delta-peak voltage
Capable of charging single cell
Able to display the charging and discharging operation to a PC via the built-in USB connector
Built-in programme for battery storage
Safety features to protect short-circuit, overload and reversed polarity
Audible alert warning and selectable melody
Adjustable safety timer
Adjustable 'Max Charge Capacity' to set the desired max charge capacity for the battery
Individual cell voltage display on LCD display
