Features
Potent new 7-port Mach 427 engine
Oversized driveshafts, bearings and axles for added strength
Revised suspension arms, hubs, carriers and spindles
20mm anodized aluminum wheel hexes
Mega Shocks with threaded anodized bodies and adjuster nuts
Losi Spin-Start Electric Starting System
Exclusive multi-speed transmission with reverse and slipper clutch
Sealed 2-speed spur gears
Steel-geared viscous differentials
Bulletproof aluminum F/R differential cases
420-Series dish wheels
Low-profile ATX racing tires
Aluminum clutch shoes
High-capacity fuel tank
Dual-disk brakes
Pro-tune linkage set
1100mAh NiMH receiver battery pack and 110V charger
Dual metal-geared Z590 steering servos
Premium JR XS3 synthesized radio with 2 steering servos
Product Specifications
Type:4WD Nitro Monster truck
Scale:Monster Truck
Length:22 in (559mm)
Width:18.5 in (470mm)
Wheelbase:14.2 in (361mm)
Weight:13 lb (5897 g)
Chassisual-deck aluminum with composite ladder braces
Suspension:4-wheel independent H-arm
Drivetrain:Center Hi/Lo trans, 2-speed with slipper and 2 differentials
Tire Type:ATX low-profile racing tires
Motor or Engine:Mach 427 (.427cc) with tuned exhaust system
Radio:JR XS3 synthesized FM system
Servos:Z590 (steering x 2), Z270 for throttle/brake & shift
Batteries:1100mAh NiMH receiver pack
Charger:110V, 100mAh overnight charger
Speed:40+ mph
Wheel Size:420-series using 20mm drive hex
Kit/RTR:RTR
Shock Type:Oversized threaded coil-over mega shock
BodyST2 Racer type, prefinished
Ball Bearings:Complete
Fuel Tank Capacity:220cc
$200 only
Dual-disk brakes
Scale:Monster Truck
Speed:40+ mph
Kit/RTR:RTR
$200 only
