The estarter is a beginner plane with a high wing, large tail dragger style landing gear and is suitable for those starting out in fixed wing flying. It has realistic proportional control like a real airplane does, using pitch, roll and yaw inputs, and is able to take off and land directly from a regular grass field.
The newer versions of the GWS estarter are made from EPO foam which is more durable but much heavier and causes the landing gear to bend open when landing. This EPS version is light and nimble with a better thrust to weight ratio and has NEVER had a crash less scratches and repaired dings on the edges of the wing.
Selling with an original gws 2208 brushless motor and esc together with three hitec servos for SGD40 neg- original value was over 100 dollars
If you're interested in a FM futaba t6xas with 29MHz rxs, you can ask in the reply below. Please dont PM. leave a question or post below. thanks!
Actual Picture as shown:
