Brushless Motor - B28/45/5 - 3600 kv
- Ideal EDF Motor for 70mm Fan units
- Diameter: 28mm
- Length: 45mm
- Shaft Dia: 4mm
- KV: 3600
- Similar in performance to a HET-RC 2W-20 Motor on 4S (B28/45/5 has higher power and Amp draw)
Condition: 9/10
Price: 20 S$
Brushless Motor - B36/50/6 - 2300 kv
- For Sport aerobatics, sailplanes and 90mm EDF Fans
- Diameter: 36mm
- Length: 50mm
- Shaft Dia: 5mm
- KV: 2300
- -Recommended Props: 8 x 5 for sports model & 10 x 6 for sailplane
Condition: 9/10
Price: 0 S$
Brushless Motor - B36/56/6 - 1800 kv
- Diameter: 36mm
- Length: 55mm
- Shaft Dia: 5mm
- KV: 1800
- Recommended Props: 8 x 7 for sports model & 10 x 6 for sailplane
Condition: 9/10
Price: 30 S$
SAPAC - 70mm EDF Fan
- 70mm EDF Fan
- not used
Condition: 10/10
Price: 10 S$
HET-RC 2W Motor with HET RC 6904 EDF Fan
- 70mm HET6904 EDF Fan
- HET-RC 2W motor for 3S (will pull 55A at full throttle)
- Powerful EDF combo for 3S setups.
- No ESC included
Condition: 7/10
Price: 40 S$
HET-RC 2W-20 Motor with HET RC 6904 EDF Fan & Tsunami 72A ESC
- HET-RC 2W-20 motor for 4S (will pull 40A at full throttle)
- HET-RC Tsunami 72A ESC (2-5S Lipo with BEC)
- Very powerful EDF combo for 4S setups.
Condition: 7/10 (Shroud intact - marks are from tape used to fix the fan in the intake)
Price: 80 S$
Condition: 6/10 (Fan works fine but has a small hole in the shroud - other marks are from tape used to fix the fan in the intake)
Price: 70 S$
WeMoTec Mini Fan 480 Pro with The Beast (Hoffman Brushless)
- WeMoTec Mini Fan 480 Pro
- Hoffman Brushless The Best EDF Outrunner Motor with 4130KV and up to 1700 watts (>1.8kg of thrust) !!!
- Use with 4 or 5S LiPo and high current ESC (>100A)
- No ESC included
Condition: 9/10 (bench run only)
Price: 80 S$
2.4Ghz Video Receiver
Voltage: 9-12V
Channels: 4
Condition: 9/10
Price: 10 S$
Hacker Master 48-O-Flight High Voltage
Manufacturer Hacker/Jeti
Applications Helicopters, Governor
Special Features Master Programming Box
Cont/Max Amp 48/52A
Cells NiMH/NiCD 10-32 cells
Cells Li-poly 4-10 cells
Voltage 12-42V
Programming Fully Programmable
Type/Max BEC (A) -
Max #Servos/V -
Dimensions 80mm x 25mm x 13mm
Weight 50g
Condition: 10/10
Price: 70 S$
Hyperion VX G3 6S 2600mAH LiPo - 35C
Condition: 9/10
Price: 20 S$
130 Brushless Motor 3000KV (EX1210 from Rotor)
2-3S Lipo
3000KV
2.3mm shafter size
Condition: 10/10
Price: 15 S$
Haoye Models 100mm EDF Fan
Condition: 10/10
Price: 15 S$
Hyperion ZS4035-10 Brushless Motor
- Made of the finest materials
- Extreme efficiency & power output
- Longest life
- Highest value
- KV: 354
- typical current: 60-95A
- Max current: 110A
- Max Power: 2550 Watts
- Lipo Range: 4-7S
- Nitro engine replacement for 60-90 size models (14-16 inch props)
Condition: 9/10
Price: 100 S$
Brushless Motor - 1200 Kv
- Bell style Brushless Motor, manufacturer unknown
- Used it before on a 3D plane with slow fly prop
- Diameter: 28mm
- Length: 32mm
- Shaft Dia: 3.17mm
Condition: 9/10
Price: 10 S$
All items are sell collect in Bukit Batok/Hillview Area.
PM me to arrange.
- Diameter: 28mm
- Length: 45mm
- Shaft Dia: 4mm
- KV: 3600
Condition: 9/10
Price: 20 S$
- Diameter: 36mm
- Length: 50mm
- Shaft Dia: 5mm
- KV: 2300
Condition: 9/10
Price: 0 S$
- Diameter: 36mm
- Length: 55mm
- Shaft Dia: 5mm
- KV: 1800
Condition: 9/10
Price: 30 S$
- 70mm EDF Fan
- not used
Condition: 10/10
Price: 10 S$
- No ESC included
Condition: 7/10
Price: 40 S$
Price: 80 S$
Price: 70 S$
- No ESC included
Price: 80 S$
Voltage: 9-12V
Channels: 4
Condition: 9/10
Price: 10 S$
Cont/Max Amp 48/52A
Voltage 12-42V
Type/Max BEC (A) -
Max #Servos/V -
Weight 50g
Condition: 10/10
Price: 70 S$
Condition: 9/10
Price: 20 S$
2-3S Lipo
3000KV
2.3mm shafter size
Condition: 10/10
Price: 15 S$
Condition: 10/10
Price: 15 S$
- Longest life
- Highest value
- KV: 354
- Max current: 110A
- Lipo Range: 4-7S
Condition: 9/10
Price: 100 S$
- Diameter: 28mm
- Length: 32mm
- Shaft Dia: 3.17mm
Condition: 9/10
Price: 10 S$
PM me to arrange.
