Gents,
Beautiful new plane, assembled but never been flown. PNF version. You require your own TX RX and 2x 3s Lipo.
Sonic Modell EPO B-17, Liberty Belle scheme.
Wingspan: 1875mm
Length: 1350mm
Flying weight: 2.8kg
ESC: 4x 20A
Servos: 6pcs
Condition: New
Modification made:
1) Pilot windscreen changed to phone screen protector material. This is so camera inside the cockpit can view far and clear outside. It was made with FPV config in mind.
2) Top portion of the fuselage was cut to be removable for a much better space management inside. This was made with FPV equipment config in mind.
3) The wings were joints securely together. It was actually slightly damaged during shipment, but was fixed. The damage was at the wing portion right below the fuselage, which was concealed once joint with fuselage. No harm was done to control surfaces.
Original purchase price including shipment: SG$381
Kindly PM or message me your offer. 9 8 7 9 2 4 7 nine
Also have master airscrew 3 blades 9x7 CW and CCW props, 2 sets.
Will throw in spare 3 blades 9x7 normal CW blades. Take all props for $40 (if you want props upgrades, or in case props damage)
Apologies in advance for not replying to low ballers.
Thank you for viewing gents.
Charles
Wingspan: 1875mm
Length: 1350mm
ESC: 4x 20A
Servos: 6pcs
Condition: New
Modification made:
Charles
