Hello,
WTS Turnigy Rotomax 1.40 and Turnigy Sentilion 100A HV ESC (used)
Previously used the two items in an ebike. Both are in good working condition.
$90 for motor
$70 for ESC, wire for anti spark plug spoilt. just need to solder in new wire
What you see is what you get.
Kindly SMS/whatsapp me at 96234077. Self collect at pine grove or buona vista mrt at my convenience. Other locations may be arranged at my convenience. Thanks
Turnigy Rotomax Specs
Upgrade your 1.40 size glow engine model with the Turnigy RotoMax 1.40 Brushless outrunner motor. This motor will provide clean and efficient power for your large scale aircraft without the mess and hassle of nitro fuel.
When combined with a 10s Lipoly battery, 20x11" Propeller and a 120Amp ESC the RotoMax motor will supply punchy, responsive power that only an electric setup can provide.
This motor is suited for wooden, carbon and electric propellers, the shaft has also been tapped to suit a 4mm bolt to make fitting a spinner of your choice easy.
Spec.
Battery: 8~10 Cell / 29.6~37V
RPM: 228kv
Max current: 75A
Watts: 2775w
No load current: 37V/1.25A
Internal resistance: 0.029 ohm
Weight: 715g
Diameter of shaft: 8mm
Suggested ESC: 120A 10S Compatible
Suggested Prop: 20x11 APC
TURNIGY Sentilon 100A HV 5-12S Speed Controller (Version 4)
The Sentilon 100A HV can handle 12 lipoly cells in series, thats 36 NiMH cells!
This BESC owes its high voltage ability to the USA imported Fairchild MOSFets used and high quality compnentry.
Now with an ultra-fast 12Mhz CPU. Faster clock cycling preventing sync loss with some large motors*
Warranted for 12 months, the Sentilon series BESCs are guaranteed against faulty manufacturing and poor quality components.
Cont Current: 100A
Burst Current: 110A
BEC Mode: N/A (no BEC)
Lipo Cells: 5-12
NiMH : 15-36
Weight: 125g
CPU Clock Speed: 12Mhz
$90 for motor
Spec.
RPM: 228kv
Max current: 75A
Watts: 2775w
Weight: 715g
Cont Current: 100A
Burst Current: 110A
Lipo Cells: 5-12
NiMH : 15-36
Weight: 125g
