Posting on behalf of friend.....
For sale a brand new never flown Jet Legend F15 turbine jet. 80% built
Scale: 1/10
Wingspan: 55"/1400mm
Length: 80"/2050mm
Weight: 19Lb
Turbine: 6-12Kg
Jet is newly built with Hitec Titanium servos throughout. Comes with a brand new i-jet Black Mamba turbine
Max. Thrust: 14.0 Kg (30.85 lb) @126,000
Residual (min) thrust @ idle: 0.45 Kg (1.0 lb)
Max sustainable shaft speed: 126,000 RPM
Idle Shaft Speed: 33,000 RPM
Max EGT: 580°C - 650°C
Response: 0-100%= 2.5sec; 50-100% = less then 0.5sec.
Fuel: Kerosene, Jet A1
Oil: full synthetic 2-Stroke Oil; Aero Shell 500
Fuel - Oil Mix Ratio: max. 4% oil added to fuel volume
Fuel Consumption: 330g/min. @ full power
ECU: FADEC V10 (Type AU-107K), c/w Handheld Data Terminal (HDT) *1)
Dimensions: 115 Ø x 320mm overall
Weight (turbine/E-start/straps): 1.55 Kg
Interested party please text me at 9644-6681
Scale: 1/10
Length: 80"/2050mm
Weight: 19Lb
Turbine: 6-12Kg
