Hi all,
3DHS 40" Edge 540 complete electric setup including receiver. Built in 2012 and flew about 20-40 times. No crashes still in extremely good condition.
Specs are as follows:
The 41 Edge is designed to be a great first balsa aerobatic aircraft. Inexpensive but high-quality, the Edge will impress you with its simple and quick assembly, honest and forgiving flight characteristics, and extremely high performance. Offering both precision aerobatics such as loops, rolls, knife-edge flight, snap rolls of all types, and all types of spins, as well as hardcore 3D with stable upright harrier, easy inverted harrier, harrier rolling, high-alpha knife-edge, hovering and torque-rolling, the Edge does it all with just a flip of the rates switch.
Removable wings make for easy transport while the stiff carbon wing tube withstands the very high G-loading of extreme aerobatics. Spring-steel wire landing gear means a rough landing won't cause damage and won't send you home for repairs - you can keep flying and enjoying!
Winspan: 41"
Length: 38"
Wing Area: 375 sq. inches
Weight: 32-35 ounces with battery, RTF
Running off the recommended OMEGA Omega 72g1100KV Motor on 11 x 5.5 prop 3s giving unlimited power. 4 Hitec HS-65 for ailerons, rudder and elevator.
The plane flies amazing, knife edge, flat spins, you name it.
Will only sell as an entire set including the receiver seen in the pictures, will also give a pair of Precision Aerobatics wing bag to keep your wings and wing tube safe. Asking for $250.00 nego for serious buyers only. Whatsapp me at 9 three 6 three 6 two nine 4.
PICTURES!!!
Winspan: 41"
Length: 38"
PICTURES!!!
