Selling my T-45 64mm EDF
hardly flying this nice bird anymore, and its collecting dust,
only made 4/5 flights after i got it.
needed quite a lot of trim on aileron and used some expo on first flights, only done trim in my transmitter, so servo rods have to be adjusted if you like to have zero trims, but after trimming out you got a nice stable flight
flown with a 2200mah 3s lipo, but power is just okey, get someone to give it a good hard trow and your airborne. good project to install a powerfull edf on higher cell count
some info,
Wingspan: 950mm
Length: 1000mm
weight: 700gr after mods (no batt, no reciever)
stock power setup
4 servo's 2x aileron, 1x rudder, 1x elevator
no rx/batt/tx
mods done
*2 servo aileron mod,
*rudder installation
*put esc in fan duct for beter cooling,
*made new nose cone full fiberglass instead of the easy breakable plastic
*glassed leading edge wing, better protection and much stiffer wing,
*costum paint job
*glassed inlets and underside nose/battery tray
*placed hinges on aileron instead of molded hinges
*done some work on cockpit to make it more appealing,
i believe its original an HK t45, a lot of info about can be found on the internet
Looking for s$ 75
contact me at sms 82 six 7 3 one 16 or whatsapp +31631 zero 058 one 4 ( my old dutch number still used for whatsapp)
some info,
Wingspan: 950mm
Length: 1000mm
stock power setup
no rx/batt/tx
mods done
*costum paint job
Looking for s$ 75
